GB Lubricants Tel: + 44 (0)191 490 4312
GB Fuels Tel: +44 (0)191 490 4311
Gear & Transmission Oils for Mercedes-Benz Vehicles
GB GERION® MTS 85W-90
Mercedes Approval : MB 235.0
A premium gear oil, which has been developed using the highest quality mineral virgin base oils and multifunctional additives, for use in final drives and axles requiring an API GL-5 level of performance. It may also be used in gearboxes, when specified by the Original Equipment Manufacturer.
SAE: 85W-90
Standards: API GL-5; MIL-L-2105D
OEM Formal Approvals: MB - Approval 235.0
OEM Specifications:
DAF;
MAN 342 Type M-1; RENAULT; VOITH 3.325-339; VOLVO 97310; VOLVO 97316; ZF TE-ML 05A/07A/16B/16C/16D/17B/19B/21A
GB GERION® MEP 80W
Mercedes Approval : MB 235.1
A premium gear oil, which has been developed using the highest quality mineral virgin base oils and multifunctional additives, for use in all manual transmissions and gears requiring an API GL-4 level of performance. It may also be used in final drives and axles, when specified by the Original Equipment Manufacturer.
SAE: 80W
Standards: API GL-4
OEM Formal Approvals: MB - Approval 235.1
OEM Specifications: MAN 341 Type E-1; MAN 341 Type Z-1
ZF TE-ML 02A/16A/17A/19A
UNIL MATIC ATF
Developed for use in automatic and semi-automatic gearboxes, and torque convertors for which the Original Equipment Manufacturer has specified the use of a Type A Suffix A fluid. It is particularly suitable for Mercedes Benz mechanical transmissions.
Performance Level: MB 236.2
OEM Specifications: ALLISON C-4; GENERAL MOTORS TYPE A SUFFIX A
GB ATF SYNTH 134
Premium quality synthetic automatic transmission fluid for use in the latest generation Mercedes Benz 7-speed automatic gearboxes. It may also be used for earlier Mercedes Benz 4- or 5-speed automatic gearboxes requiring a fluid MB p236.10 or MB 236.12.
OEM Specifications: MERCEDES BENZ p236.14; MERCEDES BENZ p236.12; MERCEDES BENZ p236.10
